10-12-2025 10:40 PM
i have no idea how my data went from 1.74 gb on friday to over 6gb when i did not use my phone for any data use i have internet at home
10-13-2025 08:33 AM
If you forget to turn the data off it will still run the apps like google maps .your internet browser
10-12-2025 11:07 PM
Where you see you used 6GB?
Login My Account using browser with incognito mode to confirm. Call *611 to confirm that usage
If it really shows you used 6GB, check the mobile Usage on your phone
10-12-2025 11:04 PM - edited 10-12-2025 11:04 PM
There are a lot of messages circulating that they have been receiving errors regarding remaining call times and data from Public Mobile.
If you know that you haven't used the amount indicated, don't worry about it. Your good.
