08-21-2020 04:27 PM - edited 01-05-2022 03:37 PM
I am on a $15/30 days plan and have just purchased 1 GB add-on data for $15.00 + tax
My understanding is that the add-on will start getting used up only after 250 MB are used up and it never expires. Is that correct ?
08-21-2020 05:00 PM
@Vazir I'm on the same plan. Another good add on to have is the 500 minute $5 one. To save more, you can add the TextNow app and use it over WiFi to make/ receive/ send calls and texts within Canada and to and from the US for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter it followed by # - and you are in your voicemail account - Hang up when you are finished. No minutes used.
08-21-2020 04:58 PM
Thanks for the satisfactory answer.
08-21-2020 04:57 PM
Thank you very much.
08-21-2020 04:54 PM
Thank you. Great help.
08-21-2020 04:32 PM
@Vazir it starts if your 250mb is used up. Carries over and only disappears when used up. Upon next renewal, you plan data again has to be used up and then the 1gig addon or whatever is left will be accessed. Stay safe.
08-21-2020 04:29 PM
@Vazir wrote:I am on a $15/30 days plan and have just purchased 1 GB add-on data for $15.00 + tax
It "expires" when fully consumed. Otherwise, yes. When you plan renews then the 250MB takes over. If you use it all then the 1GB steps in.
08-21-2020 04:29 PM
Yes, plan data is used first and once it has been depleted the add-on data is used. The add-on data remains in your account and rolls over to the next month until it is used up.
