04-22-2017 06:06 PM - edited 01-04-2022 01:42 PM
hi @Shazia_K, @Mary_M, and @Saray_O
i recently used up all my data and purchased a 1gb add-on on April 19th to tide me over until next month when my account get's renewed. I had data working until today. My account states i have the 1 gb add-on in the add-on section but in the overview secion of my account no data is showing not even the 12gb data from the original plan. Could one of you please help me out.
Thank you
04-22-2017 07:15 PM
04-22-2017 07:08 PM
thanks raven and ndesay,
after looking at the usage history it looks like i did use 1gb of data in 2 days
i guess that's what happens when you come down from a 6gb/month plan from rogers, but for the cost that public mobile offers, i'll just slow down my usage.
thanks again for all your help.
04-22-2017 06:54 PM
04-22-2017 06:48 PM - edited 04-22-2017 06:51 PM
You can go into your Account Self-Serve. Under Overview tab, click "View my Usage". Unfortunately, you'd have to manually add up each value corresponding to WEB if you're looking to track your data usage for more than one day, but sifting through those records should give you a good sense of what you used in the past day, even if you glance at it.
04-22-2017 06:38 PM
really? shouldn't we be able to see how much data we used. I should be able to see when i used the data, shoudn't I? I have a hard time believing i used 1gb of data in 2 days as I am on wifi morning, evenings. Is there a way to see when i used the data, which day used up the 1 gb?
04-22-2017 06:31 PM - edited 04-22-2017 06:32 PM
@beachhead wrote:also the issue is i don't see data on my account. I can normally see how much data is used. kind of like 10 of 12gb. i don't see those numbers anymore. any help would be appreciated.
thanks
When someone runs out of data, it disappears from an overview page.
04-22-2017 06:25 PM
thanks
04-22-2017 06:23 PM
i purchased the add-on on the 19 of april. there is no way i went through 1 gb of data in 2 days.
04-22-2017 06:13 PM
May be you ran out of add-on data as well?
