credit on my bill
EllenPatkai
Hello
I purchased a refurbished phone on October 13.  I was supposed to get a $5 credit each month for 6 months.  I have not seen this on my bill.
2 REPLIES 2
@EllenPatkai
I recall the CPO was a one time $30 credit.
Members correct me if I am wrong.
Login to your account and login again into your Rewards section and check to see if it is shown in your account.
HI @EllenPatkai
are you using the same email address as you used on My Account to make the purchase?
you can open ticket with PM CS agent and they will confirm.  Provide them the order number and email address and they will add it back for you
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
