contact a monitor
derekc
I needed to find some information I had found before but had forgotten. I eventually found it by a lengthy roundabout procedure, but one of the things I tried on the way was "contact a monitor". It took me to a screen that said "Private Messages" but I could find no way to input a message. It just seemed to be a link to Public Mobile's relentlessly useless search engines.
7 REPLIES 7
By typing if you don't have a mind machine interface for your system. Oh very important to click on Send too.
@derekc wrote:
This is NOT a solution. Many people suggested the same link, one I already had, but nobody explained how to enter a question on the page.
I don't get it. What are you actually trying to do then?
You got links to the private messaging area and were supplied the To: address automatically filled in. All you had to do was start typing a subject if you like and then the body in the bigger box. A lot like email...but it's not email.
Or do you mean posting new threads in here? Which you did do successfully for this thread.
derekc
Luddite
@derekc  Correct; that is a dead end link. Robot Frustrated
Always start in the forum if you need info/assistance.
popping
@computergeek541 wrote:
Try sending your message using this:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@derekc
Please note that moderator wait time is 2 - 3 days.  Just wait for your turn.
duffer900
