completing reister
r-w-m
I have data but no phone service after completing setting up phone. it says i am not registered
2 REPLIES 2
hi @r-w-m
are you porting in the phone number?
Please make sure your old sim card is removed (or if esim, please disable it).  Then check if PM sim is enabled and set as Primary
next, reboot phone and click Reset network settings.  You should see the phone showing connected to Public Mobile.  Test again
slusagm
make sure you removed any old sim card or disable old esim.  The Reboot phone and Reset network settings
