04-05-2020 11:53 AM - edited 01-05-2022 10:15 AM
I want to switch to Public Mobile.
My phone is Samsung Galaxy J3 Prime is not on the compatibility list. How can I added?
Phones
04-05-2020 12:02 PM - edited 04-05-2020 12:03 PM
@galinabaglay If you own the phone it will work on PM. But some sub variants don't seem to have the 4g LTE data bands. So you will only get data in areas with 3g support.Use these articles to port and activate, if required, they basically explain it all:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
04-05-2020 12:00 PM
Add the phone to the following announcement thread. Hopefully, PM will add it to the PM compatibility list
04-05-2020 12:00 PM - edited 04-05-2020 12:01 PM
Is it the 2016 or 2018 ? Is it the North American version unlocked if it then it should be compatible.
