02-13-2020 07:53 PM - edited 01-05-2022 09:29 AM
02-14-2020 12:56 AM
@scapper1 wrote:how upto date is the checking your phone to see if it will work on Pm
I guess you can tell, by the responses you've received here, that the answer to your question is, "not very". As the others have said, you'd be better off checking which bands your phone has.
02-13-2020 11:23 PM
@kselmak wrote:Your best bet is to check frequencies your phone had and compare them with telus/Bell
For taking you will need wcdma 850 and 1900
LTE would be b1,2,4,7... The more the better
If in doubt you can check with community for suggestions recommendation or feedback
A small note about that: Band 1 is not used anywhere in Canada for cellular service.
02-13-2020 08:03 PM
@scapper1 The best way to do it is to check what bands your device supports. If it shows the following then you are good to go. (the ones in green are important)
3G: B2 and B5 (calls, texts and data)
LTE: B2, B4, B5, B7, B12, B13 (texts, data)
02-13-2020 07:57 PM
02-13-2020 07:55 PM
