11-11-2022
07:10 PM
11-11-2022
07:11 PM
computergeek541
11-11-2022 07:57 PM
Same way you created this one.
Get some email, invent handle and fire away!
11-11-2022 07:50 PM
@mike1941 , you can simply log out from your current community session and start fresh to create a new account. I would suggest that doing so would water down any effort you might put into community support. As for the support system, a single community account is adequate to look after many self serve accounts.
11-11-2022 07:45 PM
@mike1941 Community account? You have setup one already. The one you are using now to post is the Community account
or you want to setup a My Account?
