code send to my new number
vey13
If I need the code to finish activate Sim number where can get the code sent to new number ?????
2 REPLIES 2
Chalupa_Batman
Hello @vey13
If you click on "Didn't Get Code" is there an option to send to your email? If not, you can reach out to a CS Agent to resolve it.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
hi @vey13
so, you activated a new line with a new account but cannot get the 2FA code?
can you receive and make calls ? mobile data works?
i am not sure if the sim was properly setup on the system. You need to ask PM support agent to check
 you can submit  ticket by direct message:
