changing plans
davegod54
can i keep my bonus minutes for int'l calls if i change plans
@davegod54  Yes and you get to keep your old rewards to if . That’s what your on check it out
HALIMACS
Yes, @davegod54 , you will retain those if you switch plans!!!  😊
@davegod54   Yes you can.  Changing plan won't affect existing addon you have now
