changing plan
giang123
i am currently on the old reward program.  I wonder if i change my plan will it also change my reward program to the new point reward or stay the same?
@giang123
It is voluntary to switch over so DO NOT switch over to the Points system and your existing rewards will transfer over to the new plan.
@giang123  No you will get to keep your old rewards I can confirm . I just  changed plans and kept my old rewards  check it out
HALIMACS
And whatever you do, @giang123 , do NOT switch to the Points program unless you want less value for your money.
HI @giang123
No change. Changing plan and rewards are different thing.  So, you will be on the same rewards after plan change
abtest
@giang123- changing plans will not affect your rewards.  you will not be transferred to the new program.
