10-06-2022 05:20 PM
10-06-2022 05:45 PM
hi to update or change your email you will have to contact a customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
10-06-2022 05:21 PM
To change your email and gain access to your account, contact agent as only they can do that for you.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
