04-22-2020 10:36 AM - edited 01-05-2022 11:43 AM
I changed my plan and autopay
its all paid up now when does my phone come back online
04-22-2020 12:22 PM
@Anonymous wrote:
@popping wrote:If your account was suspended, you cannot change plan while suspended. You need to pay the old plan and click the reactivate your plan link to get your phone working.
We can change plan while suspended. The service won't work until paid of course.
Thanks. Updated my post.
04-22-2020 12:18 PM
04-22-2020 12:02 PM - edited 04-22-2020 12:21 PM
@toddpictou wrote:I changed my plan and autopay
If you change plan immediately, your new plan should be active right away.
If you schedule plan change on your next renewal date, when is your next renewal date?
Check you account again to determine what you did?
PM plans are prepaid plans. Therefore, there is no refund of unused days if you change plan early. It is better to schedule plan change on your next renewal date.
04-22-2020 10:54 AM
@toddpictou Try resetting your network and restarting your phone. Stay safe.
04-22-2020 10:46 AM
I believe you are an existing customer who had an payment failure resulting in suspended service. what are your available funds? what is your account status?
this link might help https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
if you were in suspended state and tried changing plans without enough funds to cover teh plan cost that could have caused problems.
as you can see som additional details are needed to better direct you to the best route to take.
04-22-2020 10:46 AM
@toddpictou As others have already mentioned it should be immediate. Dial *611 from your device is you account active? If not, and you re-activated your plan try the following to get plan re-activated again. (Just keep going down the list)
wait a couple of minutes and then declare your phone found by using the same steps from above and restart your phone.
If none of the above methods work submit a ticket to the Moderator Team for help.
04-22-2020 10:45 AM
Changed from a previous carrier? Changed on your renewal? Changed immediately?
What is your account status? Do you have more than enough in your Available Funds or is it mostly empty?
Maybe restart the phone.
04-22-2020 10:39 AM - edited 04-22-2020 10:44 AM
Did you select change plan now ?
https://www.publicmobile.ca/en/bc/get-help/articles/change-your-plan
04-22-2020 10:38 AM - edited 04-22-2020 10:50 AM
@toddpictou If you are an existing customer a plan change should happen immediately.
