07-18-2019 02:00 PM - edited 01-05-2022 05:57 AM
So today I upgraded from a LG Nexus 4 to a Motorola Nexus 6. I used the same SIM card and never needed to modify it at all. The new phone shows Public Mobile up on top of the screen. The data works, the wi-fi works, I can make calls, but I cannot receive calls. Other cellular users calling my number get a message that my phone number has been forwarded. Land-line users calling my number get a message that all circuits are dead. Any ideas?
07-18-2019 02:08 PM
Try the lost phone trick. To report your phone stolen. Login to your account. Choose Plans and Add-ons tab. Then choose Lost/Stolen Phone tab. The choose Suspend Service tab. Logout. Wait few minutes. Login in and report your phone found If you still have problems tthen contact a moderator by messaging them. Moderator can be reached at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-18-2019 02:04 PM
@wolfepack , can you go into the settings on the phone dialer app, negotiate to the call forwarding settings and see what the settings are for that feature? Make sure forwarding is set only for unanswered calls. Hopefully that's the issue.
