change subscription
ming1710
why public mobile keeps letting me choose the expensive plan only, I cannot change to a low cost plan which I used before
1 REPLY 1
@ming1710
The lower priced plans are for new activations. If you changed your plan to a higher plan. You won’t be able to go back to the lower plan. This was a recent change on PM.
