change plan
MUDASAR-ZAIDI
hello there, need to change the plan from $50 to $10
1 REPLY 1
RobertQc
@MUDASAR-ZAIDIEASY! Log into self serve 🙂
https://selfserve.publicmobile.ca/
Then click "Change Plan"
Then select the $10 plan. ($10 for 50 Minutes and 50 Texts)
Click "Change plan now" if you want it immediate and to lose the rest of your $50 plan if its not expired yet.
 OR
Click "Change on next renewal"  for the smartest option if you still have time left on your $50 plan
(be patient at each step, it can take a couple minutes, don't click back or click the same button twice.) Good things come to those that wait.
