06-08-2020 08:05 PM - edited 01-05-2022 11:04 AM
I am considering buying a motorola stylus please confirm if this phone will work on the network as I don't want to change plans. Thx
06-09-2020 12:22 AM
Yup the Motorola Stylus would work for Public Mobile
06-09-2020 12:18 AM
@vicki3 only caution is you are not buying the jnternational version right? Make sure you buy one that is from the US or Canada. And you will have no issue.
06-08-2020 11:00 PM
It will work, make sure phone is turned off, when you, insert SIM card. Turn in on. All set
06-08-2020 08:19 PM
@vicki3 when you get it just swop the SIMS. If its smaller then carefully punch it out. Stay safe.
06-08-2020 08:07 PM - edited 06-08-2020 08:10 PM
@vicki3 yes this phone is compatible. if you're purchasing it from the Motorola website it should be unlocked and ready to go
