07-04-2017 03:13 PM - edited 01-04-2022 02:17 PM
07-05-2017 04:00 PM
@Joey_1975 you obvioiusly haven't met some of my family! Ugh, they can talk......
Seriously though, a lot of people just like the convenience of Canada-wide calling so they never have to think about dialing anyone in Canada from anywhere in Canada. You never have to stop and think, do I have enough add-on mins for this call? You just call and talk. If you're not lucky enough to be on one of the promo plans, all of which to date have been limited to province-wide talk option, then upgrading from prov-wide to canada-wide is fairly inexpensive at $5/30 or $15/90 days, which is a worthwhile upgrade for many. The problem is if you're on one of the promo plans and you want to upgrade to Canada-wide, you have to forfeit the extra promo discount credits which ends up costing you significantly more. Which, is unfortunate, especially if your needs change.
07-05-2017 02:31 PM
@srlawren True - 3.3 hours of long distance per month is typically enough for most people. That's if people actually still make calls .... seems that today's generation like to only text and use other messaging apps. If you're a business user and need LD - you're at the wrong company.
07-04-2017 11:18 PM
07-04-2017 10:52 PM
07-04-2017 04:51 PM
take note that if you don't have canadawide min you won't be able to receive call when you are out of province.
07-04-2017 04:10 PM
@ranjodhsingh814 as noted, the promo plans are as-is, with no substitutions unfortunately. The suggested workarounds of add-on minutes or using VoIP services work alright for most people most of the time. Please let us know if you would like any further details on either option, or if you have any other quetions or concerns.
07-04-2017 03:53 PM
Yeah, you can call US and Canada for free with Hangouts.
07-04-2017 03:35 PM
07-04-2017 03:15 PM
unforutnatley, if you change your plan, you will lose the extra data. Your best option is to buy a long distance add on, or use a VoIP service (google hangouts or fongo for example).
Just know for VoIP you will need to be connected to internet or data to use them, but with google hangouts all calls made to numbers in Canada are free
