08-19-2022 04:24 PM
Hi community,
can you someone help please?
is it just me?
trying to submit a support ticket for technical issues through the chatbot and all works fine until the chatbot provides a link to a page where i have to login with my community username and community password
after hitting enter, it shows "error logging in"
i am logged in right now, to post this question....so obviously my username and password for the community are functional
in the end i was able to send a direct message to a cust_serv_agent but i have no clue why i cannot login in to the community with the submit-a-ticket process
cleared browser cookies and history with the same end result...
what i am doing wrong?
08-19-2022 04:55 PM
@immada wrote:Hi @hTideGnow
thanks for responding, cant even get through the initial one for community login, in private mode - error logging in
agent responded in direct message with providing a shortened URL link asking to authenticate
i am kind of hesitant to provide info on a page that arrives via shortened link, can this be trusted?
HI @immada Yes, if you got it via private message from @CS_Agent , then yes, those shorten links are valid
08-19-2022 04:50 PM - edited 08-19-2022 04:51 PM
08-19-2022 04:40 PM
Good of you to have your defenses up but yes. It's just a shortened link to a Public page. The data goes into the Public system.
08-19-2022 04:38 PM
Hi @hTideGnow
08-19-2022 04:27 PM
HI @immada The chatbot login contains 2 different one
Initial one is your Community login
The one before you submit the ticket is for Self serve My Account login or your 4 digits PIN
But, if you still cannot get through the Chatbot, please message them direclty:
08-19-2022 04:25 PM - edited 08-19-2022 04:26 PM
tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
error submit ticket then contact support team by private message CS_Agent
