10-09-2019 01:40 AM - edited 01-05-2022 07:29 AM
my plan was renewed yesterday, Oct. 7. But I can't receive any phone calls but I can make calls and receive texts.
10-09-2019 06:31 AM - edited 10-09-2019 06:31 AM
Try rebooting your phone to reset it, or turning off and on airplane mode to reset network.
10-09-2019 01:58 AM - edited 10-09-2019 02:47 AM
@Roseofsharon wrote:my plan was renewed yesterday, Oct. 7. But I can't receive any phone calls but I can make calls and receive texts.
@Roseofsharon Make sure your phone's do not disturb setting was not accidently turned on.
10-09-2019 01:55 AM
@Roseofsharon Maybe you should contact the moderator directly. You can click on the question mark at the right bottom corner, then ask for a ticket. The moderator will contact you within 2 days.
In the meantimes, try to restart your phone or reinsert your SIM card and see what happens.
10-09-2019 01:50 AM
no i didn't
10-09-2019 01:46 AM
@Roseofsharon Did you forward your phone to other number? Try to call from other phone and see what happens.
