01-09-2018 07:39 PM - edited 01-05-2022 03:53 AM
I have activated my sim card, but I can't get any incoming calls, it goes directly to voicemail without ringing, I already have access to data and making outgoing calls, the only problem was the incoming calls.
04-02-2018 02:42 PM
@jeewanpersaud have you rebooted your phone since changing the phone number?
04-02-2018 12:58 PM
Hi
I changed my phone number but cant get incoming calls.
Outgoing/incoming Text Works
Outgoing Calls Works
01-10-2018 04:48 PM
01-10-2018 04:45 PM
Yes. It has been resolved. Take a bit longer than expected. But everything is good now
01-10-2018 04:07 PM
@jlai wrote:I received Mods email just an hour ago, mentioned porting is completed.
I have restarted the phone. They only fixed the incoming calls.
Texting still not working.
P.S. I posted my number yesterday. It is almost a day, and still have problem. I have been waiting patiently.
Did your issue get resolved?
01-10-2018 04:05 PM
Have you messaged them again? It took me more than 12 hours to get my number completely ported. Hope it get fixed soon.
01-10-2018 12:54 PM
01-10-2018 11:40 AM
hi @jlai
inbetween you can put back your old sim card from your old privder its will still work till public mobil will finnish to port the number
01-10-2018 11:37 AM - edited 01-10-2018 11:38 AM
hi @jlai
in order that the mod shulde fix the prablom asap
you shulde include in your msg to the mod
and your info from where your port your number
01-10-2018 11:05 AM - edited 01-10-2018 11:06 AM
01-10-2018 10:22 AM
I am still waiting since yesterday. It is now 10:30 am. Still have not receive any updates from the MOD..
Very upset with the service, specially i am a new customer. Think about to change to another provider.
01-10-2018 07:21 AM
It happened to me too when I ported in. Just be patient and send mod-team another message. They will fix it for you.
01-09-2018 10:15 PM
Looks like you will need to wait for a response from the moderators tomorrow morning. Their availability is as follows:
01-09-2018 10:03 PM
No, there is no response. Still not working. It has been over an hour
01-09-2018 10:02 PM
Did they fix it or not yet ?
01-09-2018 09:57 PM
I did send the issue to Mid with account details. No response...
01-09-2018 08:03 PM
@jlai Did you port in your number? If yes, seems like there is an error in porting process or it is not processed yet. Either way, you will need to send a private message to the Moderator_Team with your account info.
01-09-2018 07:49 PM
Try messaging a mod and tell them about your issue. What kind of plan do you have? Maybe your in an area with not the best signal so it can’t pick up on the calls. But messaging a mod and telling them about this would be the best solution, they are always looking to help and they find a solution really quickly!
