10-27-2016 07:21 PM - edited 01-04-2022 03:45 PM
i could not access to my data eventhough i have data plan. try to set up in my phone
as follow the link it still not work. and my phone does not have exact same option as i told this is manual setup for android phone?
Press Main - Select Settings - Select Wireless and Networks - Select Mobile Networks - Select Access point Names - Delete all APN's in this section. - Press Menu - Press New APN - Enter the follow settings one for General Data . The other for MMS Name: CA - Public Mobile Web APN: sp.mb.com Proxy: Port: Username: <blank> Password: <blank> Server: MMSC: MMS Proxy: MMS Port: MMS Protocol: WAP 2.0 MCC: MNC: Authentication Type: PAP APN Type: default, supl PXT Messaging MMS: Name: CA - Public Mobile MMS APN: <blank> Proxy: Port: Username: <blank> Password: <blank> Server: MMSC: <blank> MMS Proxy: MMS Port: MMS Protocol: WAP 2.0 MCC: MNC: Authentication Type: PAP APN Type: mms
Service
10-27-2016 08:03 PM
you are very welcome....please just mark your posting as "solved" ....saves some time for others ...
cheers
10-27-2016 07:58 PM
thank you guys my phone is working now thanks again.
10-27-2016 07:40 PM
hi..
yeah the APN settings you posted were wrong ..you have to change them to what i posted and restart phone after you saved new setting... ( you have to delete your old APN first though...
it should be under:
settings-mobile networks-Access Point Names ( APN )
10-27-2016 07:38 PM
it is google nexus 4
10-27-2016 07:37 PM
google nexus
10-27-2016 07:34 PM
hi..
forgot: also please restart phone after entering APN settings......just to refresh all data....
10-27-2016 07:28 PM - edited 10-27-2016 07:28 PM
@baby08 What is make/model of your phone?
10-27-2016 07:23 PM - edited 10-27-2016 07:55 PM
hi..
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC:http://aliasredirect.net/proxy/mb/mmsc
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: internet+mms
