can not send/receive pictures on Iphone 11
08-07-2021 08:46 AM - edited 01-06-2022 03:03 AM
Hello, I can not receive/send pictures on Iphone 11. Also sometimes when I am called, no any response on the phone
Thanks
Joining Public
08-07-2021 12:58 PM - edited 08-07-2021 12:59 PM
@Lucyzhou wrote:Hello, I can not receive/send pictures on Iphone 11. Also sometimes when I am called, no any response on the phone
Thanks
Reboot your phone.
If you are sending a pic to another iPhone then you should be using iMessage and can be done over wi-fi or Data. But both ends need to have iMessage turned on. If you are sending a pic to an android phone (green bubble) then you need to turn Data on to send a pic over text.
08-07-2021 11:50 AM
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit HERE
click HERE
Ensure you have the correct APN settings by visiting HERE.
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is go through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your DATA is on.
Good Luck
08-07-2021 11:37 AM
Check your settings, go to Settings>Messages>enable MMS messaging. Also check if Send as SMS is enabled as well.
