01-31-2026
09:56 PM
01-31-2026
10:09 PM
computergeek541
02-08-2026 10:23 AM
tx to all for the info
01-31-2026 09:59 PM
hi @Forsyth436
you are porting in your phone number? check if you can receive inbound calls
if you can receive inbound calls, then make sure you have latest iOS and update your Carrier Profile
then Reboot phone and check Reset network settings on your phone
