01-31-2019 11:52 AM - edited 01-05-2022 03:12 AM
I was not able change my plan via self-serve since this morning, it shows blank on plan change area, is there outage happening. I am in rush as my data ran out. thanks.
My Account
01-31-2019 02:25 PM
@randolphbenoit and if you need help here we can try to help you and if we can't tell you to write to the moderator_team...It will be easier if you need to ask questions to write a new message or question (instead in a solved subjects..) question here...https://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/getting_started....
01-31-2019 01:16 PM
@randolphbenoit wrote:Can a mod/admin from support send me a direct message have a few questions
@randolphbenoitIf you message them first, yes. Click this to send them a message.
01-31-2019 01:15 PM
01-31-2019 11:54 AM
Try a different browser or incognito mode.
If that fails try in an hour or so
01-31-2019 11:54 AM - edited 01-31-2019 11:56 AM
@cayyc wrote:I was not able change my plan via self-serve since this morning, it shows blank on plan change area, is there outage happening. I am in rush as my data ran out. thanks.
@cayycVery common for this to happen. Almost always fixed within an hour. Try again later. It happens randomly throughout the day almost everyday. One of the self-serve quirks. Make sure to log out before you log back in each time you check.
