can no longer make calls- plan doesn't cover the call
PH127
I am not able to make anymore calls. Every time I dial a number, the phone keeps telling me that my plan does not cover the call, and it is not true.
popping
Login to your account.
If your account status is active, try the lost/stolen phone trick to re-provision your plan features.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is up to 48 hours. Good luck.
Lieux
Which plan do you have?
JaimeLaPizza
What is the status of your account in the self service ?
