09-29-2018 04:47 PM - edited 01-05-2022 01:58 AM
09-29-2018 07:10 PM
@Han_15 wrote:If early renewal is possible then get on a plan that is cheap and has a lot of data. Then when you are out, you can switch back to the old one that you like
The problem is the old 90 days plan is no longer available. If one switches to different plan, s/he will not be able to get it back again.
09-29-2018 06:08 PM
09-29-2018 04:58 PM
@ShawnC13 wrote:
@Gudkov wrote:can i add more data to my current 3 month period if I'm out?
You can but it is expensive $30 1gb it you can add funds equal to your plan cost and have mods renew your plan early if you like
I am not so sure about a possibility to change a plan now by selecting the same plan? Can the early renewal possible this way? I understand this cannot be done for plans that are no longer available without mods intervention.
09-29-2018 04:49 PM
