calls
preet2175
When every someone call me or i call them i can not call them and they can not call me and on my phone on the top right coner it says sos and I have tried to turn of my phone but it still does not work i have taken my sim card out and put it in other phones and it still says sos what should i do do i buy a new sim card?
HeidiU
Hello! Are you using your phone inside a concrete building or in a basement? Try going outside and see if the SOS changes to bars.
HI @preet2175   you just activated with PM?
If you are, your sim not is not setup properly on the system, you need to open ticket with PM CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@preet2175
Did you power off the phone or just turn off the screen?
You need to power off the phone by holding down the power button and power off then power back on your phone.
HALIMACS
@preet2175
Firstly, where did you get, and how long have you had, this particular SIM card?
You can try to gently remove it and clean the gold contacts using a soft pencil eraser, or a small bit of rubbing alcohol on an Q-tip.
After it's dry, place it back in the device, and reboot the device.   Any change?
Also, try another known working SIM card in your device to see if all calling & texting features work.  This will exclude the issue as being the SIM card vs your device.
darlicious
@preet2175
When was your renewal? Do you have active service?
Did you purchase your phone brand new or from a reputable provider or retailer? Or second hand?
Log into your account and check your status of your account services....
Check your IMEI# found in your settings under About Phone...
https://www.devicecheck.ca/check-status-device-canada/
kaytus
@preet2175 may be the sim card problem. btw, can you log in the account and check your account is that active?
