04-03-2020 02:44 PM - edited 01-05-2022 11:18 AM
04-05-2020 03:33 PM
-Press the little maple leaf cartoon
-Press 'My settings'
-Press 'Avatars'
-Then you can view your current avatar, or choose another one.
04-03-2020 04:41 PM
@dabr wrote:@LarryH Did you accidently select your own post as the solution instead of one of the posters who responded to you?
You should be able to click the 3 dots top right of your post to amend and re-assign the solution 🙂
@LarryH FYI, unless you truly worked out your issue yourself without any helpful replies, it's considered bad etiquette here in the community to select your own reply as solution. I would suggest you mark the reply from @JoyLuck as the solution, as they answered your original question. @gblackma also provided useful additional information, so either in my mind would be an okay choice.
04-03-2020 03:15 PM
04-03-2020 03:04 PM
thank you so much!
04-03-2020 03:00 PM
Thanks so much for your help.!
04-03-2020 02:50 PM
@LarryH wrote:ok, thanks now I read that I can change my email under avatar, but I don't see a settings tab or heading?
Select avatar top right, choose settings, then avatars to change.
04-03-2020 02:50 PM - edited 04-03-2020 02:51 PM
@LarryH top right, next to the envelope
04-03-2020 02:48 PM
04-03-2020 02:46 PM
@LarryH do you mean the Canadian flag by your name? That avatar? Thanks.
04-03-2020 02:46 PM - edited 04-03-2020 02:49 PM
