04-19-2022 10:44 AM
I want to add a second phone to my plan. What are first steps? Thanks
Other
04-19-2022 02:46 PM
Not only does your new plan get which essentially amounts to a $15 credit, you will also get 1 dollar off a month on your old plan for the referral for as long as the second line is active.
04-19-2022 12:42 PM
Simple answer No, only one account/number.
You need to use another email address for the new SIM.
04-19-2022 11:06 AM
You cannot add additional phones to existing plan.
Only one account is allowed per one unique email. There is no 'family plans' at PM.
Meaning if you want to have 2 phones with PM account you need two separate accounts opened with 2 unique email addresses. Email aliases are allowed.
04-19-2022 10:53 AM - edited 04-19-2022 11:20 AM
Buy or get a free sim
Use your referral code and save $15 on your new plan. $10 one time credit and 5 points worth $5.
Get a second email address or use an alias
Set up a new account.....each phone needs its own account with different email address
Activate the Sim
04-19-2022 10:49 AM
Each SIM card must have its own account, therefore you will have to activate the sim with a new email address.
04-19-2022 10:48 AM
@Hyatt, you can't add a second line to the same account. So the first step is to get a new sim and create another account for your second line. Each phone number requires its own account, with separate email address (alias' are allowed)
04-19-2022 10:47 AM
None. You can't. Public doesn't offer "family" plans.
