add ons
margita_r101
I have purchased add ons for long distance but I can't use it ...Why??
2 REPLIES 2
srlawren
@margita_r101 in addition to @popping's reply, does your plan include Talk?
popping
Buying add-on is a 2 steps process.  First step is putting fund in your account.  Second step is using the same screen to use the available fund to purchase the add-on.
What is the available fund on your account?
If the available fund is the same amount of the cost of you minutes add-on, you had completed the first step.  Use the same interface again to purchase the add-on.
