activation
MH1959
My phone won't activate. What did I do wrong?
geopublic
@MH1959  If you activated your sim card and picked your plan then make sure you phone is unlocked otherwise you will not be able to connect to the network. Do you have another phone you can test the card with?
buang99
You meant sim card? Make sure you enter the correct details when registering an account.
LovesToPM
Hi @MH1959
Please describe what you did so far. Sometimes restarting your phone can get things working.
hairbag1
Did you confirm if your phone is unlocked and compatible with PM network ? Go to top of this page "Get Started".
gblackma
@MH1959  what do you mean?  Did you activate your SIM card,  did you receive a PM welcome email and was your credit card charged?  Thanks. Stay safe.
