Thursday - last edited Thursday by computergeek541
Have received SIM card, but can't activate in apps.
Thursday
unnecessary repetition removed
Thursday
already uninstalled and then reinstalled, same result.
Thursday
Try completely uninstalling the PM App, then reinstall the app.
Try the process again using the SIM card number.
Ensure you're using a new Public Mobile SIM card from a reputable source, and not one previously used. I'm guessing you are.
Thursday
@Isaacc_42 No worries get support to help then
