09-15-2022 05:25 PM
port from Bell, nothing working that around one hour how to line work
09-15-2022 06:24 PM
ok
09-15-2022 06:08 PM
It sounds like the porting was not completed because you didn’t get/reply to the text with the Bell SIM in your phone.
Just call the Porting Department @hTideGnow pm.
09-15-2022 05:48 PM
Hi @ekart when you put the Bell sim back into the phone, it is fully functional , right?
Maybe it is time to call PM porting department, they can provide you update and can advise what to do next.. Please check your inbox for the number
09-15-2022 05:47 PM
Bell sim is working but not getting any text
09-15-2022 05:45 PM
non
device unlocked
09-15-2022 05:35 PM
HI @ekart
wait for 10 mins, the text might come
When you have the PM sim in the phone, can you at least make outbound calls ?
09-15-2022 05:35 PM
@ekart ok are you getting any messages like network sim locked I'm wondering if it is locked to bell
09-15-2022 05:34 PM
puting back but no text
09-15-2022 05:33 PM
nothing work
09-15-2022 05:32 PM
@ekart hi nothing working at all? not even outgoing calls or text or data?
09-15-2022 05:31 PM
HI @ekart Put the Bell sim card back to a phone and see if you get the text. Reply YES to the text. You might still have time within the 90 mins
09-15-2022 05:31 PM
send a private message to CS_Agent
09-15-2022 05:30 PM
no i am not getting any text but i take out Bell sim
09-15-2022 05:28 PM
HI @ekart did you get a text from Bell to ask for you to approve the porting? did you reply YES within 90 mins?
if you already pull the Bell sim off the phone, put it back in, you still have time to reply the text , it still within 90 mins if you only requested the porting an hour ago
Let us know if you see the text after you put the Bell sim card back
