activation impossible loop, requires phone number to get sim activated
galenthurber
activation requires Eversafe login via SMS to the unactivated SIM
What is the work around?
galenthurber
user I'm helping is still stuck
galenthurber
thanks we will try, I can create a ticket for new subscriber
galenthurber
it is the app the user is using, it is trying to send a SMS to unactivated phone
@galenthurber are you using the app for activation?? if not, please download the app, put in the sim card and try
if issue persists, please open ticket with PM support
HALIMACS
@galenthurber
You must activate using the Public Mobile app.
You will need to follow the steps carefully.
If you don't want to download the app, borrow a device capable of downloading it, then after you're all activated, simply delete the app from that device.
You can then access self-serve to manage account via website, no app needed.
