12-28-2025
04:05 PM
12-28-2025
06:13 PM
computergeek541
12-29-2025 06:08 PM
@JCfromBC , are you @Indira2 ?
did you login PM app using the same login you used when you activate on the browser earlier?
you might want PM to help to sort it out. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
12-29-2025 06:04 PM
Samsung 4G phone. Got a PM sim card, installed it, paid for a plan online, downloaded app. The app gives me no buttons to choose a new number or to do anything else. Just says "almost there". Suggestions?
12-28-2025 05:04 PM
If you are looking at activating a new account. Here is the instructions for opting your number over to PM:
If you are an existing member. Call 1-855-4PUBLIC to enable AutoPay on file. If the system can’t find your number then your account is closed due to nonpayment longer than 90 days. In this case, you need to start from scratch and open a new account.
12-28-2025 04:14 PM - edited 04-06-2026 12:00 PM
do you want to activate a new account or resume service for an existing account?
if it is a new account, use the PM app to subscribe. But if you want to resume service, you need to login the acocunt yourself and make a payment. If you cannot login, ask PM to sort out the login issue.
Since you cannot login and cannot use Chatbot, you will need to send PM a message
