activated the wrong imei
Alishasp
anyone know how to fix?
Alishasp
thank you it worked
Alishasp
yes I have sent them a message waiting for a reply. in theme time I just ordered a physical sim
slusagm
Did activate PM eSIM on yhe wrong phone or you provided PM the wrong IMEI for porting?
If eSIM on wrong phone , you can just download PM app on the right phone and login and buy new eSIM
If wrong IMEI provided for porting, message PM and ask provide them the old provider account number (do not use IMEI)
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
porcupine
Try rebooting your phone and if that doesn't work click on the pink envelope in the bottom right corner for help and follow the prompts
