03-13-2022 01:25 AM
I have put an ad on in my account today and I made a mistake and put Us data for 15$ and I wanted to have the 20$ usa roaming ( text) . When I want to add this past one, it stated that my account is not activated, however I auto pay on March 7, 2022. It should work. I have no data and no internet and no text. Please help!
03-13-2022 09:40 AM
@DesangesD wrote:I have put an ad on in my account today and I made a mistake and put Us data for 15$ and I wanted to have the 20$ usa roaming ( text) . When I want to add this past one, it stated that my account is not activated, however I auto pay on March 7, 2022. It should work. I have no data and no internet and no text. Please help!
@DesangesD - where is it saying that your account is not activated?
You cannot use addon services on a suspended account, what does it say for status when you log into your self service account?
OR,
Can you call 611 from your device, or call 1-855-478-2542 from another line to check the status. You can also use these number to purchase roaming addons (you need your 4 digit pin to do so).
If the account is suspended and you are showing enough available funds, is there a resume/reactivate option on your self serve account?
If you do not have available funds, add funds manually equal to or more of your plan amount and they select to reactivate service.
03-13-2022 08:15 AM
OK @DesangesD , first things first:
You should then be good to go.
03-13-2022 05:42 AM
The $20 roaming add-on includes data but so does the $15 data add-on. Try buying an add-on that doesn't have roaming data like the $8 roaming text or the $15 roaming talk and roaming text add-on.
