account get locked..
03-10-2024 10:06 PM
Hi
my account get locked out , said will be unlocked after 3 hours but still it is locked. Can you help me to unlock ? or reset the password for me.
email is : hali.can2021@gmail.com
Thanks,
My Account
03-10-2024 10:15 PM
We are all customers like you. If you are able to get back to your message, click on the circle beside the time and edit your post to remove your email address and press post.
03-10-2024 10:13 PM
What happens when you try to reset the password yourself?
If still not able to access, submit your request below.
Or use the following if above doesn't work to an agent directly.
