03-10-2024 10:16 PM
03-10-2024 10:33 PM
make sure your cell is volte enabled by PM, otherwise there's no talk in Alaska with PM add-on. Others have successfully used add-ons in Hawaii...but Alaska...not so much without volte.
03-10-2024 10:21 PM
Thanks
03-10-2024 10:20 PM - edited 03-10-2024 10:21 PM
HI @Way1
both Alaska and Hawaii are included
in Alaska, make sure ou manually connect to AT&T
for Hawaii, you can connect to either T-Mobile or A&TA
Of course, make sure you enable Mobile Data Roaming on your phone
