about new plan
zmh1175
I just changed my plan to the new one which is 12gb
90 days for 120 dollars. but it will change on Jan on my next billing date. I want to know is the plan will be changed on that date? since the promo is end on nov 2rd. thanks
Danath
zmh1175
thnx
JaK
Hi @zmh1175;
Yes, as long as you do the change before Nov 20th (which you have already done), then you will get the new plan at the promotional price on your next renewal, even if after Nov 20th.
