07-14-2026 01:13 AM
Hi,
I have switched to a 4G LTE/5G device, can you please make sure I would not be charged with this extra fee next month? Thanks.
07-14-2026 01:22 AM
here's some reading re: VoLTE ...there's a device checker at the end of the article. Not all 5G devices will work in Public Mobile world. If your cell isn't compatible, you'll continue to be charge the $5 until you do get a compatible cell.
07-14-2026 01:17 AM
the system might take a bit long to remove the $5 surcharge. It is best to open a ticket with PM agent and have them to remove the charge manually
Please open ticket with PM support:
