04-20-2022 05:16 PM
Does anybody know the Xiaomi Poco F3 work on public mobile network or not? thanks.
04-20-2022 05:36 PM
One of my friend also have an Xiaomi phone with PM and it works fine!
04-20-2022 05:26 PM
It does my buddy had one but near the end of his first month he dropped it in the toilet like an idiot so ended up getting another phone lol so as long as you don't drop it in the can like he did, you should be fine
04-20-2022 05:19 PM - edited 04-20-2022 05:23 PM
HI @TIANRUI Yes ,it will.
Here are the bands the F3 has and the BOLD are the compatible ones on PM network:
3G bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands 1, 2, 3, 4, 5, 7, 8, 12, 17, 20, 28, 38, 40, 41, 66
Looking at this, it should work well
Update:
But if you are just planning to buy, you might think twice, check this thread, at least 2 members reported issue on both PM and Telus:
So, it might be good on paper, it might not pass the real world test
04-20-2022 05:17 PM - edited 04-20-2022 05:18 PM
Yes it will, @TIANRUI
It has the necessary 3G and 4G / LTE bands for network coverage under public mobile.
