5G/4G not working on POCO X8 Pro Max
Irtiza
I bought a 100GB 5G subscription (Esim) from public mobile. 5G/4G doesn't seem to work. It shows 5G on the status bar but nothing works. Calls and SMS seem to work though.
I also used fizz before using public mobile, and with fizz 5g was working and everything else too.
1 REPLY 1
kb_mv
@Irtiza So everything else works and it shows that you are on the 5G network with Public Mobile but data isn't working? Have you tried resetting network settings?
