02-28-2019 03:20 PM - edited 01-05-2022 06:45 AM
02-28-2019 03:38 PM
@ShawnC13 wrote:
@CS_Agent wrote:Hi therefenix333
You can check the compatibility of your phone in the following link: https://www.publicmobile.ca/en/bc/get-started
You just need you IMEI number, you can get it by dialing *#06#
Kind Regards,
Rod,
Public Mobile Moderator Team.@CS_Agent, and @fenix3333 , I would not use the PM tool for compatibility it is actually for lost or stolen phones on the black list and does nothing for network compatibility and often comes back with false results. A better site to use is www.willmyphonework.net
Be careful suggesting willmyphonework for overseas brands that are not sold in large quantities in North America. The Mi A2 Lite is not on their database. That said, in general, Xiaomi sells two variants for each model of phone. One variant would be referred to as the global model (not to be mistaken for global rom) which includes band 4 FDD-LTE (1700/2100 Mhz). This is the model to buy. If you see TD-LTE in the description, that is the overseas variant and will have limited band support here.
02-28-2019 03:28 PM - edited 02-28-2019 03:33 PM
Kind Regards,
Rod,
Edited to add a google translation
Moderator Team and fenix3333, Je ne voudrais pas utiliser l'outil PM pour la compatibilité, il est en fait pour les téléphones perdus ou volés sur la liste noire et ne fait rien pour la compatibilité du réseau et revient souvent avec de faux résultats. Un meilleur site à utiliser est www.willmyphonework.net
02-28-2019 03:26 PM
Hi therefenix333
Kind Regards,
Rod,
