Xiaomi Mi 9
davis_j
I've just returned from China, with Xiaomi's latest flagship (the Mi 9), and I'm pretty sure the only reason I don't see it in the compatibility list of phones, is because nobody's tried one here yet.  I'm 99% sure it would work, and be compatible.  Is there a way I could take it into one of your kiosks to test a SIM in it to verify?  Thanks 🙂
2 REPLIES 2
geopublic
@davis_j  If it's the global version should work without any issues.
Dunkman
@davis_j
It should work.
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
https://www.gsmarena.com/xiaomi_mi_9-9507.php
It has the necessary bands to work with PM.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
