How are rewards calculated?
yiatioxi-ok
How are rewards calculated in general? --------Are rewards given only for solutions given?
@FrankLp wrote:
Anyone ever had the full 20$?
Just how much active were you on the forums during that month?
When you see a poster with a little orange star next to their username, they are what are called Oracles. They're still customers like everyone else but they've earned their way there. They're the only ones that get $20.
The rest of us fight it out for the lesser rewards.
popping
Only the Oracle members get the $20.  Other members get max $15.
FrankLp
Many have gone about attempting to game the system. They're usually found out and figured out and called out.
The thing I think we don't like seeing is giving yourself a solution. Ask a question and then solve it yourself and then give yourself the solution. Frowned upon.
will13am
Community rewards are determined using a secret formula that basically takes into consideration the participation level.  Solutions, posts, bravos, etc. are considered.  If you are interested in community rewards, simply participate and let everything else take care of themselves.
