Wonky notifications
darlicious
I read that something was up with the notifications but why am I getting ones chronologically all over the place? Some are two weeks old, some a week, some 4 hours all mixed up with current ones. Pretty sure there isnt a random button in my settings.
What's with the multiple threads with the same answer from @popping under the navigate the community title?
15 REPLIES 15
@Anonymous
Huh? 7:35pm? Well your solution fixed both the timing and order of the posts. I dont seem to be getting any more old notifications mixed in with new ones.....
Edit: Not too clever today.....lol
@darlicious wrote:
@Anonymous
Why don't you quote me quoting you and then I can give you the solution....
 @darlicious
I don't recall seeing notifications mixed up. Just posts in threads.
But if you like, 7:35pm will do on that.
 @darlicious : click the link under the time.
darlicious
@Anonymous
@will13am wrote:
Fixed through settings change as recommended by darlicious.
Hey! I'll take that credit thank you very much 🙂
I noticed it earlier. Me and kevenv and a new guy wbg13 nailed it down.
permalink
zomba
I guess there a network delay that's why you are getting plenty of same notifications, try to restart your cellphone.
I had a post earlier today that showed before other posts even though it had a later timestamp.  I haven't checked to see if it fixed itself
@computergeek541 wrote:
@will13am wrote:
@Anonymous wrote:
 @darlicious : I'm not talking about notifications. I wasn't in that thread.
I'm talking about the mixed order of posts in a thread. That seemed to have changed today. Replies to a post earlier in a thread were showing after the post it replied to. Not chronologically as it has been for as long as I've been here.
So I changed my settings to Oldest first and that fixed it to list in chronological order. The default is thread order which apparently places replies after the post it replied to. I hadn't changed anything before that. Something got changed in the background.
 @will13am : if you reply to a post earlier in a thread then look at the thread again, your reply would be after the post you replied to. Not at the end.
Several people have been observing this.
I am not seeing any weirdness here.
I'm seen in in a few threads, but most are fine.  If I log out and look around, messages are over the place in random order.
I am not seeing any weirdness here.  Oops, I spoke too soon.  The hamster wheel is broken.
@darlicious wrote:
@Anonymous
Here's your solution to my question.....
Re: Overwhelmed
@CFPartDeux wrote:
Hmmm, seems like something else has been messed with around here - my reply from 2 mins. ago is showing up ahead of your reply from 56 mins. ago...... 😮
 @CFPartDeux
Some switch was flipped in the system earlier today. Go to My settings/Preferences/Linear Layout and choose Oldest first. Then it'll be back to what it has been all along.
I was going to ask whether you broke the hamster wheel.  All difficult problems have a simple resolution.  😛
BTW, I am on default setting.  Seems fine.
HALIMACS
Anyone else getting wonky notifications or is this limited to a few?
@Anonymous
Re: Overwhelmed
 @CFPartDeux
@Helpershelper
The times are off as well....
Helpershelper
Maybe their experimenting with a new notification script on their back end
