Won't receive 6 digit code
Jensence
Jensence
No, when I hit resend code it refreshes and the 5 minute timer restarts.
there is no option after Resend code is clicked?
if that is the case, you will have to check with PM.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Jensence
Unfortunately that's not even an option. All I have is resend code
hi @Jensence
did you mean the PM 2FA code? are you new subscriber with porting in phone number? if you are, check the phone with your old carrier, it could have been sent there if porting was not done yet
or you can try to click Didn't Receive code, and check if email or voice message are options, try both
if nothing work, ask PM support agent to help.  You can submit  ticket by direct message:
@Jensence  If you tab didn’t get code you should get option to have code sent to email instead , but if it’s not working just message support to help
send  a  private message   To CS_Agent
slusagm
try receive via email, click Didn't receive code or Resend code and then Send email
